Did this problem just start?
I had a heat issue for the 200 mile drive to Carlisle in July but it never got too bad. I had to put the heat on at one point...
Is there a shroud?
No shroud from the factory...
Was there one from the factory?
Do you burn regular ethanol pump gas in it?
yes regular gas 93 unleaded....
gauge reads a touch over mid way.. It's the dummy gauge in the dash....
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
