I like the boot seals that the later transmissions use.
http://www.ebay.com/itm/131071796547?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
You can't use that without modifying the dipstick.
when I put together a 727 I makes sure the dipstick hole in the trans and the dipstick are oil free , put on the o ring the tube and put a big bead of copper type RTV around the tube below the o ring , put the tube it and let it sit over night in it's secured position , no leaks .
