This is a revisit as I never got this issue resolved.
When I first turn the starter over, it cranks as if the battery is weak (or hot starting) barely turning the motor over. But once it makes the first revolution, it turns over fine.
It never fails to start but something isn't right!
Battery is in the bed, new starter (have tried other starters).
Entire Thread
Subject
Posted By
Posted
Initial hard to crank over but then turns over good...?
