Take the car out and find out what is does now, adjust as needed AKA go run the car, if it spins real bad to start with loosen up the front shock retaining nuts and washers at the track so the front end will try to transfer weight.My biggest concern on your car is th fuel system, the stock 5/16 pickup and fuel lines will probally limit your top end charge Go have some fun and see whar it does, as you can see from these posts everybody has thier own opinions based on their past expereinces or what they've heard
