My 440 coronet has an oil leak I believe is coming from the rear main. Can too much oil pressure cause this. Going down the road hot 80lbs. Up to 100lbs when cold. It has about 45lbs at idle. It's already blew out the oil sending unit. I run 10w-40 oil. Thanks for any input
