It's a 2001 Four Winds Hurricane 31' Class A puller. V-10 Ford engine. Ihe frame goes clear to the back, but the last 2' is poorly welded to the rest. I can strengthen it to make it work. The bad part is it has a shorter wheelbase with approximately 9' behind rear wheels, which from what I'm told will flex and cause issues no matter how much I reinforce the frame.
With 9' behind the axle its gonna flex the frame and
body pretty good even with the toad... it would still
have the side to side load... I put another X brace
on the back of my Rampage chassis so I could pull
a LIGHT small trailer.. without it, it would have
flexed the body
