72-85 Crewcabs are all the same. the bulkhead hole is different for the wiring and the hvac I believe is different (both mentioned pertain to 72-80 vs 81-85) The rest is the Same. the Standard cabs are what changed as in the roof skin was redone and the above mentioned. Clubcabs follow the same criteria as the Crewcabs
