Sorry guys the jet size I got before was from Summit Racing info, but was incorrect.
Here is the specs on the carb-
PRIMARIES SECONDARIES
IFR 56 56
PVCR 44 BLOCKED
PV 5.5 BLOCKED
JET 96 106
IAB 67 67
HSB 24 24
SQUIRTER 45 50
ACC PUMP 30 50
EMUL 1 BL BL
EMUL 2 BL BL
EMUL 3 62 62
EMUL 4 BL BL
EMUL 5 62 62
I used the numbered bit to measure all the sizes with the exception of the HSB and EMUL. All my small bits(60 and up) were out of order due to the case coming apart. I read what I thought was 62 on the emulsion bleed and 27 on the HSB.
