I have a question for you guys...in a drag race only application....red tops or yellow tops?
I've seen a couple NHRA Stockers with the D51 yellow-tops, but they use 2 of them. I only use 1 battery with an alternator at the moment.
if you run an alternator use a red top. if not yellow
For anybody racing and running fans etc the yellow top will be the way to go, alternator or not.
68 Barracuda Formula S 340
