What I got with the combo I have is 14.5 compression. stock block-494ci eddy/mopar heads 72.4cc
Diamond pistons 4.355 bore 14cc domes .015 in the hole 4.15 stroke eagle crank-6.760 eagle rods-going to use fel-pro 1105 gaskets .051 thick. does have billet steel main caps. no fill. Tell me what you think ? Thanks Jamie
