You want the white round plastic head on the switch plunger to be way over to the pass side so it contacts the pedal arm not the MC pushrod or the bolt head. As said pull the wires/remove the switch/bracket & bend it flat & mock it back up. It sure seems like it is way off (but as we know pic perspective does lie) which I ain't grasping how that happened since you never moved/unbolted the mini screw but only undid the big bolt/nut to replace the MC
