Personally,if you are doing only a limited amount of racing I would use the Mopar Perf replacement Hemi / 6pk pan,you will have all the oil you need and still looks stock.Here is an original Max Wedge pan,they were not run on the street.Guess how much it holds.
Bill, I'll guess 7... ..Looks like an extra quart over the hemi pan...
