915's run about 84cc if I measured right , 516 ??? Do NOT use NHRA specs, they are smaller than actual.
I though they were like 78
That's the NHRA spec and it is WRONG
NHRA spec for 906 is 79.5 cc ... WRONG
NHRA spec. has nothing to do with actual chamber volume on a stock head. It's the volume that you have to follow to build a legal stock class racer.If you're under their spec in CCs,then your car would be illegal.
