I used it in this car. I won't burn your paint off if you have a leak or bad cap. That said you have to empty the entire system, clean it and then you can add it. You can't mix the 2 as far as I know.
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
