My air hose/pipe was rusted through, too, so I removed the pipe, cut the flange from the pipe, plug welded the hole, and re-attached the flange to the head.
Well that answers that,What you describe is EXACTLY what I had in mind.Your engine didnt suffer any ill effects did it?
