Does the 66 already have the 8 3/4 rear? If so just change springs and center section, nothing special about the Hemi or 440 rear.
Good point. The 66 models still used the 8 3/4" axle, just the weaker 741 chunk. The housing and axle shafts are the same as they used for the higher HP cars.
