I'm going over the finish line at 7300 and would like to see it around 66-6700 rpm.Could this be done by going from a 31 inch tall tire to a 33 inch tall tire??
Would also like to loosen the stall but that would increase the RPM at the stripe.
Now have a Dana with 4:10 & 31 inch tall tire. Peak Tq is around 5000 RPM and HP is 6200
Al, that must be a inefficient converter. I go through at 6900 with 4.10/10.5x31W/147 mph. Flash stall is 5700 rpm
Doug
