Sounds like whatever you had worked well.
Why not have whoever built it make you another
The converter is five years old and has maybe 50 1/8 mile passes and I'd guess less than 3000 street miles on it. The 60' and mph started going away two years go, I've lost .3-.4 in the 1/8.
At first I thought it was a transmission problem. At cruise in high gear if it was matted the rpms would jump to 6000 then pull from there. So I built a new 727 over the winter, everything new. Put it in and the same thing as the old one on the street. Pulled the new trans and let a local shop take it apart and find where I had screwed up. I picked it up yesterday, they didn't find anything wrong.
So I don't want to spend the money to have this one freshened up and have the same problem start in three years. I'll spend the money on a good one this time.
Send yours to Lenny....that's what I did....picked up 5 mph and I have run it behind three different motors ranging from a 446-512. Works great behind all of them. I might be leaving a little on the table since the 499 in there now makes more steam..but..it runs the numbers..
5.53 @ 125 1/8th on the launch control..more left in her!
