You want no less than 1&1/4 times the bolt dia, that amount of thread engagement including gasket/washers etc & a bit more than that is OK. Mockup what you have & if you have a certain # of bolts of a particular length/thread/etc that might help you group them. Most critical is the DR front of the block where the front cyl wall on that bank is the closest
