On my 66, with a 904-6cyl trans when the car sits (converter drains back) my shift selector seal is leaking. Since I am going to pull the valve body to do this seal, I want to replace the throttle shaft seal as well.
Does anybody have a good part number for these I can get from Napa or Advanced /ect?
Thanks, Joe
BE SURE to clean up both shafts of rust and corrosion OR that will chew-up the new seals.
