a drive-line issue will not feedback thru the steering wheel on your 2WD Ram. You have bad tires and or balance issues and or worn out front end parts. An acceleration vibration or shake will feedback thru the whole truck and is a different and separate issue.
Put jack stands under the lower control arms out as close to the wheel as possible so the ball joints are unloaded.
If the steering and suspension checks out ok, there is a problem with the tires
