BBD's are very easy to work on. A gallon of carb dip, some spray carb cleaner, and a rebuilt kit (and maybe a float) would take care of it.
Or, just hit up your choice of parts stores and they will probably have a re-manufactured one in the system.
If it is an original carb and you go the re-manufactured route, then keep your original and just pay the core charge. You might want it later down the road.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
