If replacing the entire core support I would weld a brace from frame rail to frame rail on the bottom to keep them from moving and either weld or bolt something across the top to hold it. Just cheap insurance that way you know it doesn't move and of course measure 12 ways to Sunday to make sure it held. I would also do what I could to save the original core support especially the section with the numbers.
Careful, your character's showing!
