it would get worse as they day went on and also if it got hot out.
Usually it would dead hook hard the first 1 to 3 passes...then start spinning slightly the rest of the race day
The first few runs it was planting the tire hard enough
to set the tires and the shocks worked good at that
point... did you ever loosen up your shocks when
it would spin... maybe just 1 or 2 settings
