I'm sure I've told you my cam specs before, but here you go... .672"/.651" lift 276°/284° at .050" 112 LSA Comp 943 springs...225 psi on the seat, 600 psi open. DLI roller rockers. Been using this same setup since 2006. Mild setup that's eally easy on parts, but makes good power. ![](/ubbthreads/images/graemlins/thumbs.gif)
