Quote: Been asked before but not answered ... What lower ball joints will you be using to solve the ackerman issue? I had the opportunity to look closely at an assembled front end over the weekend and I don't think you can get the outer tierod end anywhere close to where it needs to be with stock spindles and rotors.
I've got a lower steering arm designed and in process. I've got a 3D model of it I can post later today.
67DartGT, your front end looks really good!
Thanks. Its really Tory's front end, cant wait for this weather to break so I can try it out.
Brett Miller W9 cnc'd heads STR Chassis fabraction
