yep, you do not want to remove the slave and then push the clutch pedal. the self adjusting spring in the slave will push the pushrod all the way out and the pedal pressure will pop it out of the bore. Now, I can hold the Prod all the way in and the pedal will not move it. guess it is all going to come apart now. just wish I could do it with a cardboard creeper and a floor jack.
Not sure if I am understanding things right here, but if you are saying the slave isn't stroking, maybe the master is bypassing, internal leak?
What does the inside of the firewall look like?
I had a '93 Jeep Wrangler, same symptoms (I think) clutch master was leaking at the firewall, and not releasing the clutch.
It takes gasoline to interest me.
