Re: 78 4X4 diff. problem
[Re: 440trk]
#1573407
02/09/14 08:48 AM
02/09/14 08:48 AM
Posts: 2,141 junction city oregon
viperblue72
Do you need a Dana 60F or a Dana 44? The HOUSINGS (respectively) are pretty much interchangeable from 1973-1993, so they should be fairly easy to find. Heck, if you shop around, you can probably find one that already has the proper gears in it. Dana 44's are very common, as where a 60F will be harder to find, and more $$$$
I would use a differential out of a 75-93 model. On the earlier divorced transfer case trucks, the pinion angle points farther down, increasing the drive line angle. Just find a unit that has the same gears, and swap it. If you find a locking hub model, you can swap your stuff from the ball joints out. I wouldn't recommend keeping the full time junk, but the part time has a different wheel bolt pattern A 3/4 ton dana 44 will work just as well, but you will have to swap everything from the ball joints out, and 4.10 gears are most common. The full time stuff commonly has 3.55. Good luck.
