were they available in 93 with power windows?
Got two '93 Ramcharger LE, both w/ PW. The 318 drivers side window broke yesterday, motor runs, no movement. You can slide the window up and down by hand about half way. I'll be looking into it soon, suspect stripped window motor gear.
Robert
Take the flat plate off the gear drive on the motor and replace the broke plastic pieces with steel ball bearings and it will work better than new..
