I asked on the A12 site. It serms that you could order the A01 light package with the N96 option...just not the L31 fender mounted turn signals by themselves. If you have a map light, trunk light and ignition delay, you would have fender turn signals too.
M Code Bees do not code N96 so that's kind of a non starter.
L31 IS a valid option on A12 Bees.
L31 is not part of A01. It's a separate option.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
