One complete door on my car, with window frame/window, quick remove hinges, latches, bodywork/paint (they are straight as an arrow) and limiter straps weighs 12 pounds.....
I'd like to see a lightened stock door and all of the above weigh only 5lbs more.
I don't buy it for a second.
Iam sure that is correct but he was asking to keep all the hardware plus he would not have take off doors so add the hinge to the weight and glass.For a low 7 second car i could see going to fiberglass doors with nothing on them but again he was not asking that.Add the mechanism and other hardware ,hinge you wont be at 12 lbs
