IIRC they are all Torx.Its been a while since Ive had one apart.Once the screws are out they snap together.Then you have to work it over the ignition key.Mopar is one of the easiest systems to take apart.Get a flashlight and look up in the holes.You will see the heads.Rocky
Chrysler Firepower
