I have finally fixed the problem with the passenger side mount. I spoke with Schumacher. They were very helpful with the problem. They recommended moving the hole on the passenger bracket forward. I reamed the hole forward a 1/16 to 1/8 of an inch. Re installed everything and the mount fit perfect and the tranny lined up perfect with the floor hump. Looks like the k-member perch must be slightly out. This explains why my passenger side rubber mount broke before the drivers side.
