Quote: Find you a mid 80's Dodge pick up with the 833OD in it They made a gazillion of them with /6 in front of them so they aren't beat up and they have the correct length tail shaft so it's a slam dunk for a B-body. I've heard that they had the iron case too so you avoid or at least reduce the countershaft issue the aluminum case has. Kevin
You heard....
I have three of them, none of which have an iron case.
Well I thought I heard it here.
Maybe some early ones got iron cases that were left over from when they quit building the regular 833?
In any case I think even if you had a machine shop bush the aluminum case, you would still have a pretty cheap bolt in OD.
