As long as you have the parts in hand you might as well see if they bolt up. That seems to be the way a lot of us have found how all this stuff goes together. Chrysler probably used the same backing plates based on drum size for 7.25" and 8.75" stuff. Let us know.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
