Quote: Check and see if the roller wheel you want will work with your cam. Different diameters change the rate of lift and may be too fast or too slow for best performance.
Explain please. Makes sense???
Think of it just like rollout on a tire. Now approach a bump in the road with a really tall tire or a really short tire. Does that change the way the car "feels" across the bump........yes sir, big time.
