have a standard bore RR hemi block with 13 # vin and interested if anybody may still have the car and be in need of the original motor. the vin is for a post car not a sedan. # RM21J9A2033##.
I left off the last 2 numbers of the vin so if you come this close we can go further with the numbers. I may also have a 4 speed trans to I will have to check the numbers on the trans.
