Ron, I believe the hood you have the double-hump scoop on is a sled city piece. The hemi style scoop is easy to mount; we did it on the Fury. Just need to measure carefully and make it square. If you want the change for hood clearance issues you can always cut the carb like we did on the polara. I have always liked the double-hump better.
