I used a needle scaler on lots of areas.
It worked great.
Okay, I give up, what is a needle scaler? In answer to leaving it on I'm running fenderwells so the area where the coating is will get hot. I'm leaving the coating in the upper fender well alone.
http://www.novatekco.com/html/needle_scalers.html
