if you keep the back spacing the same on both wheels you will increase the wheel width by 1/2 on both the front and back side like you have already pointed out Did you measure both sides? If not you should , it is not uncommon on all types of Unibody Mopars to NOT have the samm clearances on both sides The section width on both sides will increase also By how much I'm not usre of
