ok im working on a friends 70 cuda 440 with six pac ... ALL NEW CARBS
I have no Vac leaks i can find.. It will only run/idle if i have the crub idle turned open to 1/3 throttle ... and then it runs for a bit and stalls out ..if i turn the mix screw ( ether way )it will die off ...
now it does run backwards when you cut off the key ... but the timming is in the sweet spot and there is no Vac advance hooked up on the car ..
I was thinking power valve it toast ? to start
1965 Ply "RAMCUDA" got to see it!!!<--- Should sell it/ 1970 Superbird <------ Just one big argument/ 1980 Jeep CJ5 <--- Just wheel it/ 2000 Dakota R/T <--- Should Drive it more/ 2001 Dodge Caravan <----- Cant kill it/ 2004 Dodge 2500 4dr DIZLE 4x4 <---- LOVE IT !!! www.moparalley.org
