You will also have to use the 99 flexplate on the 94 motor for the converter bolts to line up. 96 and up have a 90 degree bolt pattern. Earlier models have one offset hole for the converter bolts.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
