You probably lost a ground somewhere in the electrical circuit. My 66 coronet would lose the temp and fuel gauge when fuel ground would lose its ground.
Be sure the cluster itself is screwed tightly to the dash frame....the cluster itself gets its ground this way
1MYTGTX
