I just found out the trunk floor should be replaced on my 70 challenger and I want to use the AMD one piece panel but ive heard there is no way to get it in unless you remove 1/4 panels or tailpanel which I will not be doing.
whats the best solution/compromise?
I used the AMD one piece floor and got it in. But if I remember correctly, we had the Dutchman panel and hinges off to do it. I think it was more of the hinges off more than the panel.
That is how I did mine. I have also heard you can remove the panel under the tail panel. Or get out the and cut it in two.
Bob
