I bought this one last fall. http://www.ebay.com/itm/361440-CHRYSLER-...=item27cdf0ca61 Works great, no issues. Temp definatelystays at the stat more consistently, and drops quicker than it did with the stock unit. I don't know what spending more could have done for me (??).
i would be careful with that pump! i had one that didn't last long bearings went out and let the shaft wobble and ruined my brand new radiator. Also next time you have the housing off run your finger in the bottom right side water port. if you can't fit your finger in it with room to spare like a stock one it is restricting flow! been down that road as well! 440 source crap is what i had!!
This one is not a source set, it came from ProComp. I'm aware of the passage issue people have posted about. This one is pretty open, I could put my finger easily up and around the bend. I'll watch the pump bearings, but as I said: so far so good. ![](/ubbthreads/images/graemlins/thumbs.gif)
LemonWedge - Street heavy / Strip ready - 11.07 @ 120
