diameter/length are critical in header primary tubes for pressure wave tuning/scavenging & all that good engineering stuff but after the collector flange you want NO restriction/back pressure. With manifolds same deal you want NO backpressure. I firmly believe that people who claim to have slowed down after adding a larger ex/tail pipes/muff system also changed something else at the same time which actually is what caused the slowing down.
