i thought they were dipped in gloss black enamel which would dull to a low sheen after a while in engine bay heat. you can clearly see the dip line inside the horn and it would create an air lock so the paint wouldn't get in the guts of the horn. you can also tell the angle that they were hung to do this. sorry for throwing a spanner in the works.
all the best
frank.
