Now that I need a 26 inch radiator I need a part #. Without breaking the bank who's got em. I seen 1 for 1200$$ thats not going to happen. I want a stock copper rad. no aluminum. Also will need shroud is it metal in 68 or plastic. Thanks Larry J
Larry did you post what trans and axle package you have so you get or look for the correct radiator. I know that 047 are just as much repo wise but easier to find used
