Its not so much they are intact but they wear.Like a speedo gear that wont turn.The teeth wear donw and dont engage right.They used to sell a repair kit.It was cheap if still avaliable.Is this an older model with solids?Id pull the valve cover and check lift and do a compression check.Rocky
Chrysler Firepower
