I was told by Dave Smith at Pro Trans that I would have to adjust and reset the front band after 25 runs with a aluminum drum in my 727 I would check it after 25 runs and write down how much adjustment it took and do it agian after 25 runs and see how much wear has occurred.
Did it need adjusting?
And did you see any ET or MPH changes?
